Canadian_Rainbi
Jan 17, 2014Explorer
Mandalay Parr wrote:
I would change the fuse holder first. You can always measure the voltage across the holder to see what it is. Ideally it should be zero or close to it at rated current.
Can't measure the voltage drop across the fuse holder without cutting into the wire insulation so I'll do that when I'm changing it.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
