Canadian_Rainbi
Jan 17, 2014Explorer
smkettner wrote:
I would just move the controller. Use the Prosine battery connection if you put controller in that compartment.
If space permits and venting is good I would also consider moving controller into the battery compartment.
Yes replace the fuse holder.
I am not sure you are too far from full but the move will help.
The battery compartment is certainly well ventilated: the batteries get covered with dust, gravel and/or moisture, depending on road conditions! :E
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
