MrWizard
Jan 17, 2014Moderator
Microwave on inverter is a BIG power hog
try to keep the MW use on shore power
it might be more efficient operating mode to allow the converter on 24/7
and turn it off ONLY if you need too when using A/C or MW,
IF batteries are at full, then converter power use will be greatly reduced and not impact your 120v use
maintaining power being used, is a lot more efficient than replacing huge amounts of power
let the batteries carry you during power outages, not full time
as far as series panels
my 2000e is not rated for the PEAK voltage that (2) 130w panels would produce
all my panels are parallel for that reason
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
