Almot
Jan 19, 2014Explorer III
The importance of having the right setup.
Remote voltage sense and remote temp sensor is a must. It might sound that your current problem is the voltage drop, but in Mexico in winter the temp sensor is at least same important. When there is 70F in shade in daytime and 35F at dawn - what else can I say...
Don't rip anything out yet. Just run a length of #8 TNN wire from local Ferreteria, in parallel to existing wiring and see if it helps. Decent electrical supplies are a problem there, but when you are not moving anywhere you can use whatever you have.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
