time2roll
Jan 19, 2014Nomad
The hardest part is covering the hole it will leave in the kitchen.
Leaves 3 options IMO.
#1 move controller: If there is any slack in the wire you just remove controller and wire nut ++ & -- at the controller location.
Then cut the wire in the battery compartment and insert controller. Just toss it in somewhere.
Make it nice when you get home. Still optional the pull big wire and re-install into the kitchen or remount properly in the electric compartment.
#2 Ground the negative output from the controller and repurpose the negative connection as positive. This assumes you have two wires from controller all the way to the battery.
Pull a proper single wire upon return.
#3 Live with it.
#3 Live with it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
