BFL13
Jan 19, 2014Explorer II
Looks like you can go from a junction box on the edge of the roof with a wire pair down the front of the rear slide opening, tucking the wire pair behind the wiper, then over under the slide to go in the top of the compartment door you can slam the wire pair on, or else put a "cable hatch" in the door.
When the slide is closed it will hold the wire pair in place so you don't even need the white plastic water pipe I mentioned before!
Meanwhile, you could move the controller to the compartment- not nailed down yet- and use jumper cables end to end down from the roof to the array side of the controller and another set of jumpers controller to battery.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
