LittleBill
Feb 24, 2018Explorer
grizzzman wrote:SparkDr wrote:
Grizzman, your post came in while I was typing up my most recent post. Have you actually used this mooshimeter? If so, I’d love to hear your thoughts on it in more detail.
I talked my work into buying one. I liked it so much I bought one for tinkering at home. In fact it is sitting next to me. It has five points past the Decimal Point. With a 24 bit resolution DAC. You can zero it on any measurement. I have been happy with it so far. It graphs is adjustible data points. I have not used the data logging yet, however I bought it with this in mind.
i have used it, i own the same meter, you either have to cut the case in a specific area, or take the meter apart to take the sd card in and out.
you can do different time internals, the unit works fairly well, and appears to be quite accurate,
you can also just leave the meter, it has no requirement or a phone to log the measurements.
you are REQUIRED though to setup the meter with a phone initially.
another nice feature is the meter is 2 channel, it can do amperage as well as voltage in the same graph etc.
example of the logging is below.
Clicky
