landlordy's avatar
landlordy
voltage question 110 on shore power 100 on inverter???
Just noticed tonight while installing a new outlet on my rig that when I am connected to shore power I get about 120 on my meter but when I unplug it and switch to the inverter I am only getting about 100? My tv, microwave, etc all work fine but this surprised me a bit. Is this normal!? Any input is appreciated.
  • MEXICOWANDERER wrote:
    Unless you have a top-tier true sinusoidal inverter it can easily confuse a digital gauge. This is why I carry both digital and analog (needle) type panel meter sets.
    What is this "analog" you speak of ?
    Oh, you mean my Simpson 260 !
    Same question, same answers from a few weeks ago.
  • BLF that is exactly what it is doing 97-100 and it is MSW so maybe I don't have an issue. Mexi I'll try an analog meter tomorrow I don't have one but ill ask my neighbor or pick one up lol. Larry the batts are fully charged. Thanks so much guys
  • Some inverters allow you to select a different voltage. Typically with PSW 120, 115, or 110. 100 suggests to me that the inverter is MSW.
  • If the inverter is MSW your ordinary voltmeter will read 97 or so it varies. You need a fancy meter (RMS something) to get the "real" voltage.
    If the inverter is PSW then it should read the full 120, same as shore power.
  • Unless you have a top-tier true sinusoidal inverter it can easily confuse a digital gauge. This is why I carry both digital and analog (needle) type panel meter sets.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
