road-runner
Aug 24, 2015Explorer III
Assuming the voltage regulator is an autoformer, yes it will result in you drawing more amps and increasing the risk of tripping the main breaker. You devices will draw more power (in watts) at the boosted voltage, resulting in more amps at the lower voltage of the shore power connection. The maximum power you can draw from the pedestal is the breaker size multiplied by the voltage. When the voltage is lower, the available power is lower.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
