pianotuna
Aug 05, 2016Nomad III
You are wrong. This is a properly installed 30 amp outlet at a private residence. The outlet is in brand new condition and is a nice tight fit. It is connected to a 200 amp service panel that is 2 years old.
SoundGuy wrote:
A voltage drop of 10 volts over just 60' of 10 gauge main service cable is excessive with just the A/C as a load and would suggest inadequate source wiring feeding the source box. For example, with an unloaded source input voltage of 115 vac and an assumed load of 15 amps you should see an average voltage drop of just 1.8 volts over 60' of 10 gauge main service cable.
Voltage Drop Calculator
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
