SoundGuy
Aug 05, 2016Explorer
SoundGuy wrote:
A voltage drop of 10 volts over just 60' of 10 gauge main service cable is excessive with just the A/C as a load and would suggest inadequate source wiring feeding the source box.
pianotuna wrote:
You are wrong. This is a properly installed 30 amp outlet at a private residence.
A voltage drop of 10 volts over just 60' of 10 gauge main service cable is "wrong" when the load on the circuit is just your A/C? :h That's funny, particularly since you obviously have a problem with this "properly installed" 30 amp service and don't even know it. :S
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
