BFL13
Oct 21, 2019Explorer II
time2roll wrote:BFL13 wrote:Not buying it. How about an empirical test?time2roll wrote:
The quote is from what make and model number?
See answer to question about what gen and why
https://powermaxconverters.com/bowfishing-gear/
Note this is about powering trolling motors mostly ( amps wrt to thrust, etc) so not same as RV battery charging. Some interesting stuff though.
OK, you do it and let us know if your converter fries. :)
I see the advice above to do a cool down for the gen's benefit, so those who run out the gas to keep the carb clean, take note. I assume the cool down is to unplug all loads "early" and then let it run out of gas.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
