Carvin_Marvin's avatar
Dec 31, 2015
W-22 engine water pump
I need to change the engine water pump. Does anyone know if it can be done with out removing the fan? It looks like there may be enough room to set the fan forward. If not I guess I will have to split the shroud and remove the bottom half to get the fan out. Anyone been there done that? 2002 8.1 in a Southwind. Thanks
  • I know what you mean I had to add an extra bolt on the bottom of the shroud to keep the fan blade from rubbing it. Thanks for the reminder. Marv
  • Beware of a blade tip eating a radiator tube. I used to force decorative wall laminate then duct tape them. They always ended up scarred.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
