Searching_Ut
Sep 30, 2016Explorer
I've had 5 100 watt panels flat mounted on my roof through this summer, and most of the time they peak out at around 25 amps. My Bogart SC 2030 will only pass 30 amps, but will handle quite a bit more than that and just clip the excess. As a result I've just recently added a 6th panel. If you tilt the panels, climb up on the roof occasionally and clean them off etc they put out a fair bit more output so results can vary significantly.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
