- Mickeyfan0805ExplorerThanks all - I'll check it out. I appreciate the input.
- tragusa3ExplorerWe do this often on a 20amp service from family and friends garages. Works out fine. It will trip if we put the hot water on electric or try the microwave or coffee pot. We've learned to manage just fine. We don't turn off the other breakers with 20amp service, but we do when using our 2400 generator. The most surprising draw in our camper is the convertor that charges the battery.
- BruceMcExplorer III(Just joking, son) Or you could have a qualified electrician install a 30a 120V RV receptacle for you.... but do you trust any "qualified" electricians??? (/joke)
To reiterate: 15A or 20A will do ya, yea, that's the ticket! - beemerphile1ExplorerAny 15 or 20 amp circuit should operate it providing the A/C is the only thing on the circuit.
- LwiddisNomadTest the generator, rk? Oh!
- sgfryeExplorer
MEXICOWANDERER wrote:
- Outlet in your garage has 20-amp service. Looks like 15-amp but has a cross-cut in the neutral slot
- Use a 12 gauge extension cord
- Flip breakers inside rig to turn off everything but the A/C
- The A/C should start and run. As long an nothing else is connected the 20 amp breaker will carry the load.
X2
This is what we do.
Ac runs fine and our resindential fridge runs normal also.
Batteries charge, fridge gets cold and ac cools down the rig. - marcsbigfoot20bExplorer
I have connected several brands of 15K roof airs to a 20 amp receptacle.
Not only do they start fine, they RE-start fine against high head pressure. This is for testing not a permanent installation.
THIMK!
30 amp to 20 amp
Rigs connect to 30 amp service AND operate their hot water heater, refrigerator, and converter AND the 15K roof air...
What he said.
I picked up a Kill-A-Watt plug in meter at Harbor Freight on sale a while back. I took the time and plugged it in to my TT AC line using a 30 to 15 amp adapter. The house circuit it plugs into is 20 amp (former submariner, I have all my house circuit breakers and what they supply mapped out ;). My AC is a 13,500 BTU and measured a constant 12 amps on high. Actually 1446 watts.
I did the same till my killawatt burned up. - wa8yxmExplorer IIITurn off all circuit breakers in RV save MAIN and A/C. use a 20 amp circuit and a 12ga extension cord. you can get those at Home Depot, Lowes or Sears/K-mart, The latter has one with a push button on the outlet. I like it.
- BoomerwepsExplorer
THIMK!
30 amp to 20 amp
What he said.
I picked up a Kill-A-Watt plug in meter at Harbor Freight on sale a while back. I took the time and plugged it in to my TT AC line using a 30 to 15 amp adapter. The house circuit it plugs into is 20 amp (former submariner, I have all my house circuit breakers and what they supply mapped out ;). My AC is a 13,500 BTU and measured a constant 12 amps on high. Actually 1446 watts. - MEXICOWANDERERExplorerPROFILE
2006 Suburban 2500 with 8.1L engine, 4.1 gears, upgraded hitch and MaxBrake controller towing a 2013 Rockwood 8312ss.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
