CA_Traveler
Sep 02, 2016Explorer III
BFL13 wrote:Lots of equipment fans run to cool after shutdown. However total shutdown on occasion should be expected by the designers with no ill effects.
I noticed one time recently the charger fan kept running after I had turned off its 120 input. The temp controlled fan in the charger had come on while it was charging so the unit was hot when I turned it off.
I thought this was peculiar since I normally unclamp the charger from the batteries and would not then see that. It is not good to have another draw on the batteries, but now I see the reason is to help cool it down after you shut it off for installed converters.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
