BFL13
Sep 08, 2016Explorer II
This is a post from a while back from the guy that counts I guess. Maybe PT can reach him as a fellow forum member? Also the post itself has some relevant info perhaps.
GBaxter
Arlington WA
Senior Member
View Profile
Offline
Posted: 10/19/12 05:07pm Link | Print | Notify Moderator
Just to confirm it is "real load support" meaning the inverter is in parallel with the incoming ac either shore or generator power. The "Almost instantaneous transfer" is a bit of a disclaimer meaning the inverter is in parallel with the incoming ac source but if the ac source goes away the internal transfer switch still switches and there could be a slight notice of power switching. Basically we are not going to "guarantee" 0 transfer time under all conditions.
The input transfer realy is a single leg of 120 Vac @ 60 amps.
Gary
GBaxter
Arlington WA
Senior Member
View Profile
Offline
Gary
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
