Unsure of the category for this question... Once you've used a good oxidation removed product and have a bit of a shine is there anything else you can use to make it look extra shiny? Something tha...
If you don't want to wax that often. Right after removing oxidation wipe surface down with a 20% alcohol water solution and then apply a sealant. It last much longer then wax. If you want a super shiny surface apply colinite after the sealant. A little colinite goes a LONG way.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: 50 minutes ago
