cannesdo's avatar
cannesdo
Wash 'n wax...
Unsure of the category for this question...
Once you've used a good oxidation removed product and have a bit of a shine is there anything else you can use to make it look extra shiny? Something that just wipes on and doesn't have to be wiped back off?
  • How can you tell if there is no gel coat left on fiberglass? Front and rear caps on my 04 Carriage Cameo are oxidized. After washing and allowing the body to dry, if I rub my finger over the fiberglass caps, I get white on my finger but not from the sides. Have Marine 31 Gel Coat heavy oxidation cleaner along with Meguiar's 67 Marine-RV One step compound aggressive cleaner plus polish and a couple of other Marine polishes, cleaners and waxes along with an orbital polisher/buffer. I live full-time in it and my main problem is that it is in the full sun and after 6 months, the caps get heavy red and green algae build up. Due to change in health, I don't feel it's worth spending big money for maybe 5 more years of usage.
  • Daytona7,
    Gel coat is the colored layer of fiberglass. The gel coat is just glassy smooth which creates the shine. When it oxidizes it's no longer smooth enough to reflect light in one direction.
    Read up on the ZEP sealer. You might save a bit of work.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
