4x4FF's avatar
4x4FF
Washer/Dryer hookups
Hi All,
I purchased a new to me 2007 5th wheel that has a washer and dryer in it. Apparently the model I purchased was prepped for it when new. I have 2 water lines with plugs in them that run to the bottom of the coach (Below where the washer/dryer are located). I assume that the plugs are to winterize the water lines for the W/D??
I have never messed with a W/D in a 5th wheel and am not sure just what these lines purpose is. All the plumbing is ran in the walls and not visible.
Any info would be appreciated,
Thanks,
Steve
  • The location may just be a coincidence. If it is just lines hanging down underneath I would also think it is low point drains. I also have two water lines hanging down underneath, but mine do have manual valves in the lines that I can open to drain the lines.
  • I would imagine those are the 'low point' drains.....used to drain the whole plumbing system (Hot/Cold water lines)
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
