Fosters's avatar
Fosters
Waste Valve Always CLOSED or Always OPEN?
Research, Previous Owner, & 1 or 2 RV Owner's I happened to ask: Conclude and Advise me to ALWAYS LEAVE WASTE TANK CLOSED till she fills so the Tank can build Gravity for BOTH the dirty waste and semi-dissolved black waste to ALL exit the tank and force of gravity to force down the sewage line and into the waste station. So........once a week every Sunday I Empty my Waste/Black Tank.
And for my Grey 1 (bathroom sink & shower) and Grey 2 (kitchen sink) I ALWAYS LEAVE THEM OPEN, period.
I've been helping a fellow RV Elder here in the Campground with changing out his propane tanks. And I happened to ask him who is helping him pull the Waste Valve every week or so? He said What???? So I explained the above, and he called it B.S. Told me as long as I have a slope/pitch on the sewer line I am fine and to LEAVE MY WASTE VALVE OPEN ALL THE TIME!
He is an older gentleman and has been RV'ing for some 5 decades he tells me, i.e. why he calls what I am doing B.S. He has a 5th, but very older model (if that has anything at all to with it, but I tend to believe not or ?).
Ok folks, the Voting Machines are now open and THANK YOU TO ALL IN ADVANCE, as I'm a full-time RV'er now entering cold Winter on the East Coast! So am I going outside every Sunday like a dope or am I going outside like a smart RV'er taking care of his Coach so NO waste build-up occurs in my Tank, possibly hardens n hardens n hardens and suddenly no room for waste and then a back-up into the Coach Toilet Floor...Yikes!!!
  • I leave my black tank valve closed until the tank is at 3/4 or more, then drain. And run the black tank flush after that.
    I suppose there are some tank designs in which his method would drain ok. But I would not want to try.
  • On a risk-reward basis, what can happen if you do it the old timer's way vs what happens if you keep doing it your way? :)
    BTW it is not the gravity, it is to have enough water in the mix to properly flush your tank.
  • He is one LUCKY camper if he has not had a pileup and clogged tank.
    You are doing it right. Only change would be to close one of your gray tanks a couple of days before you empty the black tank so you can open the gray to help FLUSH out the hose after you have dumped the black.
  • Fosters wrote:
    Translation?
    If you leave the drain valves open, your poop forms a pyramid in the holding tank.
    An RV toilet is not like a home toilet, where every flush uses a two gallons of water.
    Poop will build up in the drain hose if you leave the valve open.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
