dougrainer
Mar 15, 2018Nomad
Since you have a FR brand. State what brand Water Pump you have. FR is known for installing the cheapest off brand or knock off brand parts in their RV's. Since you have replaced the pump, that should rule out the pump check valve, but if NOT a name brand(Shurflo or Flow Jet), then I would suspect the brand water pump is failing at its check valve. Now, if you have a valve that allows you to pressure fill the Fresh Tank when on city water, then THAT valve would be suspect also. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
