Dutch_12078
Mar 15, 2018Explorer III
wnjj wrote:dmjaway wrote:
As far as I know, there is only one way into the Fresh Water Tank, (via the external fill port) and only one way out of the Fresh Water Tank, (via the water pump, first passing through the WP filter).
There is also a vent, though it’s not likely to be a source of water.
A city water tank fill setup is often just a valve controlled bypass around the pump that uses the tank outlet as an inlet.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
