gbopp
May 27, 2014Explorer
It shouldn't be a problem. If it was dripping and you stopped the drip, it may have just been dirt or corrosion on the seal.
Personally, I wouldn't worry about it. If it makes you feel better, get the new valve and take it with you. Then if it is a problem you have the replacement.
Mine dripped a couple years ago. I just opened the valve (after bleeding the pressure) and closed it after running a little water out of the valve. No problem since clearing the valve.
Enjoy your trip.
Enjoy your trip.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
