dougrainer
May 27, 2014Nomad
The Texan wrote:
No problem at all. it will "gradually" get worse, but there is NO hurry to change it. Also, it is a common item available at any hardware store, NOT RV specific. Just pull it so you know which model you have, there are 3 or 4 different ones and go to your local store to get a replacement. I was in the same boat and went a year before I changed mine.
They ARE RV specific. The Temp rod is shorter than a standard residential Pop Valve. So, make sure the Hardware store one has the shorter rod. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
