Old-Biscuit
May 27, 2014Explorer III
Clay L wrote:
Regarding the air pocket. The following is from the Atwood manual.
"To replace the air pocket start by turning off the water
heater, shut off the incoming water supply
and open the closest hot water faucet. Pull the
handle on the pressure-temperature relief valve
straight out to allow the water to flow from the top
part of the tank. Once the water has stopped
flowing allow the handle on the valve to snap shut,
close the faucet and re-engage the water supply."
Same info in Suburban manual.
Water expands when heated....air pocket allows for expansion
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
