wolfe10
Jun 25, 2016Explorer
Could be clogged evaporator/condensate drain OR could be bad base gasket (the one around the 14X14" roof opening.
Could also be a combination. Once on the roof, easy to tell-- check the condensate drain first-- and while there probably a good idea to clean the condenser!
If that is not the issue, then buy a new base gasket. Yes, sometimes you can tighten the 4 bolts and further compress the old gasket, but they DO have a finite life and are not expensive. Pretty easy work with two people due, not to weight but to size of the roof unit.
