ToastHater's avatar
ToastHater
Water Filtration System
I'm working on a plan for a DIY RV build, and I wanted to incorporate a water filtration system. Specifically, with sustainable boondocking in mind. I'd like to be able to clean any incoming water to the freshwater tank, as well as recycle gray water if possible.
From the research I've done, there are two solutions that are very similar: reverse osmosis or ultraviolet light. Both incorporate or require a pre-filter. RO requires higher pressure. UV requires a lot more power.
My understanding is that RO is the most effective, but least efficient. And that the efficiency is related to the required PSI to run it. In-home units, needing 60-70 psi or more and being less efficient. Restaurant units, needing 100 psi or more and being more efficient.
[Gray Water/Water Intake Tank]
{High PSI Pump}
{5+ Stage RO System}
[Freshwater Tank]
{Low PSI Pump}
=Out to Sink/No-Tank Water Heater=
=Sink - Out to Grey Water Tank=
Trying to keep things tight, so it isn't all over the place. I also may not be incorporating a shower within the RV, and I'll be using a composting toilet. So the only thing going into the grey water system, would be water from the sink.
I'm curious if anyone has experience with either of these systems. More specifically, how frequently do they need to be maintained/replaced?
Would you trust either, to filter grey water?
Given the available power, could they be combined together? The RO system feeding the UV system. Would this be too redundant and over the top?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
