- Old-BiscuitExplorer III
sch911 wrote:
Make sure to remove and clean the very tiny hole in the gas orifice. This is where most dirt lodges....
Clean ONLY by soaking in alcohol and then blow dry.....just 'whistle'
Do NOT poke anything thru orifice OR use high pressure air
The orifice is metered and can be easily damaged. - sch911ExplorerMake sure to remove and clean the very tiny hole in the gas orifice. This is where most dirt lodges....
- Bessie-HunterExplorerLow gas pressure will cause it to flash back at the orifice.
- snowpekeExplorerMight have spider web in there.
- Old-BiscuitExplorer IIIWhile you are cleaning up the burner tube & orifice.....run a wire thru combustion chamber and out exhaust/tie a rag to it and then pull rag back thru to 'chimney sweep' combustion/exhaust
Just needs a little 'routine' maintenance (housekeeping) - Clean the burner tube and orifice.
- EverettherringExplorerhttps://www.facebook.com/1472875773/posts/10211907757317312/
This video. - HelimechExplorerWhat Video?
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
