enblethen
Sep 25, 2014Nomad
I would take the flex line off that feeds the rigid line and inspect it or replace it.
I would not think that the rigid line could be an issue.
Yes, you could take a major line loose and use a strong air compressor to blow out the lines. Remove line from tank area so as to blow only the pipes and not any device such as gas valves.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
