MFL
Dec 26, 2014Nomad II
Rmack1 wrote:Escargot wrote:
The magnesium anode is recommended by Suburban, unless it lasts less than a year, then they recommend the switch from OEM magnesium to the zinc/aluminum rod.
This is interesting info. Mine erodes away very fast, so you're saying Suburban recommends the zinc/aluminum anode rod now?
Escargot is correct, if your anode is completely used up, in less than a year, you need to switch to aluminum. If it erodes fast, but still has 25%, at years end, stick with the magnesium.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
