Rmack1
Dec 22, 2014Explorer
Water heater anode rod change frequency
I understand that you are suppose to change your WH anode rod every year under normal circumstances. I learned that lesson the hard way.
Ever since, I've put nothing but softened water into my tank. I think once I let the regen cycle go until I read just a little above the least amount of contaminates color. I fixed that fast, and have used only softened water that tested at or very near the lightest (best) of the test strip colors.
It's been about a year since I put in a new anode rod. Do you think I could get away with a little more before changing it again, since it shouldn't have had to be working that hard?
