dougrainer
Apr 23, 2019Nomad
Remember, IF the 120 side is working and you have a full tank of HOT water, The LP side WILL NOT FUNCTION. The Tstat/s have been satisfied and the heating modes will not come ON. When you have your type problem you go to the Water Heater and open the POP OFF valve. If you have HOT water come out, your water Heater is functioning and you need to find the BYPASS valves and set them for correct use. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
