dougrainer
Mar 30, 2017Nomad
DougMatthews wrote:dougrainer wrote:
IF you are testing while the burner is ON. WHY????????? If the burner is ON, the Tstat has not reached its shut off temp. LET IT RUN UNTIL IT SHUTS OFF. Then test your water. Doug
The unit used to reach temp and shut off in under 10 min (anecdotal, never measured).
Seems that if it is barely warm in 30 minutes it's going to be hours (if ever) before the Tstat shuts it off. That won't support taking a shower.
/Doug
NO RV water Heater will reach temp in 10 minutes on LP. Let it run, see if the burner shuts off. What do you have to lose? Doug
