wa8yxm
Mar 30, 2017Explorer III
Where are you measuring the water temp?
If it is at the faucet the #1 cause of such things is a shower either inside or outside, the mixing valves are open and the head valve is cut off.
If the water in the tank is not getting hot.. I'd guess an obstruction, either in the burner orifice as others have suggested or in the flu/heat exchanger.
