Old-Biscuit
Apr 27, 2014Explorer III
Your gas control is leaking thru.
The brass screw in is the main orifice......changing it will not solve your problem.
You need to replace the gas control assembly.
You probably have a Robertshaw 'Unitrol'
Replacement......LINK
You may have to redo inlet connection if your current one has the inverter flare inlet(no longer available)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
