Old-Biscuit
Apr 04, 2014Explorer III
Should be a plastic clip that holds the check valve internals (spring/plunger) in place.
With needle nose pliers you remove clip and then pull the check valve out of nipple.
OR take a screw driver and break it up then pull the pieces out
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 22, 2026
