RLS7201
Nov 11, 2022Explorer II
wa8yxm wrote:
There are a few thigns that can cause "Rough" burning and other problems
Insects sometimes nest in the hot path...
Dirty Gas Jet (Orifice)
And in your case the suspect #1 is the air/fuel ratio.
There is a sliding collar on the large burner tube just past the gas very much smaller gas jet.. at high altitude you need to slide it so the "Windows" in the tube open a bit more.. Your eyes and ears are the "Meters" you use to make the adjustment You want a clean flame and proper sound... The OWner's manual if in color, has photos or you can to the thing I don't like... YOU TUBE
Here is the RV Doctor https://youtu.be/nSjDklZh4ws
The information you provided is wrong. You provided info for an Atwood water heater.
Richard
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
