Old-Biscuit
May 18, 2021Explorer III
If element is burnt out......No 120VAC acroos the black/white terminals cause element is burnt out
Disconnect the white wire...check continuity across the two terminals
Burnt out..no continuity
Check for continuity across white terminal to element flange...got continuity element is shorted
Either case new element
Atwood uses a 1400W 120V element
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
