12th_Man_Fan's avatar
12th_Man_Fan
Water heater element
I bought a new Rv and I noticed there was a on off switch on thee outside of the unit for electric operation. It was hidden behind some tape.
Well of course i had it plugged in with the water tank empty.
When I noticed what was going on I disconnected the element and checked it with an ohms meter and it shows a solid short.
Does this mean the element might be ok? I can only plug in to 20amp service where it is parked so I can't check it through the electrical system.
Thanks in advance for your help.
Doug
  • It should last 2 to 5 minutes with out burning out. 10 to 12 ohms would be good. Check both across terminals (10/12 ohms) and terminal to ground (infinity)
  • Bobbo's avatar
    Bobbo
    Explorer III
    Generally, a bad element shows an open circuit, not a short. Fill it with water, turn off all the other circuits, turn on the element and see if the water gets hot.
  • Apparently you are indicting that it was taped to the ON position?
    I would have thought new would have been taped to the off pos.
    Mine has a safety pin for locking it in the off pos. :h
    I found a great youtube on how to test the element.
    Doug
    If it's a Suburban it's probably toast. Attwood, there is a possibility that it still works. 20A service should be plenty of power to test the heater. Just don't have any other high amp items on at the same time.
  • Dead short most likely would have tripped the breaker.
    Fill with water and give it a go. Element draws about 12 amps normally so 20a service is fine with everything else off.
