Chris_Bryant
Aug 01, 2014Explorer II
You need to physically run a brush through the burner tube? You are not getting enough air- usually because the lp isn't traveling fast enough to draw in enough.
Problem could be low LP pressure, dirty orifice, or a spider web in the burner tube (in reverse order of odds :)).
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
