Shadow_Catcher's avatar
May 03, 2016
Water heater heater
When boondocking (we rely on solar), in our teardrop trailer it can get a bit nippy during cold weather.
I had been toying with a number of ideas over the last few years inspired by some one in Russia that was planing on living in his teardrop full time. My idea at the time was to use an external fired boiler running into the tear with an automotive heater core and fan.
This evolved into an idea of using our water heater (rare in a teardrop) as heat source. I posted that idea on the Teardrop & Tiny Travel Trailer forum and then started working on it.
Picked up a new automotive heater core, a 100mm computer case fan a 12V solar hot water pump a thermostat and two double shut off quick disconnects. The hose is Tygon food safe reinforced hose. All the bits and pieces are food safe and well with in the heat range put out by the water heater.
Others have tried this and it works well. The whole setup is very quiet and works well. The thread is here Water heater thread
  • OK, being a former plumber for the record they are not HOT WATER HEATERS they are WATER HEATERS because if the waters hot why would you have to heat it?? Sorry had to get that off my chest.
  • I must confess, I did not read the entire linked thread!
    What is the rating of the Water Heater in BTU/Hr?
    Edited to remove the word "Hot."
