bob213 wrote:
Would some one please refresh my memory..Thermostat position....
Gas left--electric right?
Opposite
120V AC Left........BLACK wires
OEM Standard 130*F is 232306
Optional 140*F is 232317
12V DC Right........RED wires
OEM Standard 130*F is 232282
Optional 140*F is 232319
IF wire to t-stat has rubbed against edge of cut-out for t-stat or if connected wire from Top (HI) to bottom (normal) is burnt into no 120V can get to element
IF HI t-stat has tripped you can push to reset it when water temp has dropped below 110*F
This one shows burnt connector wire on 120VA AC set
