SlowBro's avatar
SlowBro
Explorer III
Mar 30, 2015
Water heater large yellow lazy flame, lots of odor 10' away
I have a Suburban SW6DE. It seems to be heating water but the flame is large, yellow, and lazy. I'd expected tight and blue. I closed up the door and after about an hour or so, 10 feet away could still smell it.
Manual says "If the burner flame is yellow and has an erratic pattern, shut unit down and contact a qualified service agency."
I didn't see any air shutter with which to adjust the flame/air mix. Is my only choice to take it to a mechanic, or is there anything I can do for it myself?
  • ronniedean1234 wrote:
    enblethen wrote:
    The burner tube needs to be cleaned.
    X2, Probably mud dauber or cobb webs in the burner tube, easy to remove and clean out...
    X3 Had the same problem - spider web in the burner tube.
  • YouTube has lots of videos on how to fix/adjust water heater - worth a look.
