time2roll
Dec 20, 2014Nomad
Replace only as needed and you need a new one. Typically the T&P safety valve is a bit smaller than a home unit so you may need to order one as Home Depot probably does not have it.
Precautions? Let the water heater cool overnight, turn off water supply, and verify no hot water pressure before you unscrew the valve.
I also recommend a small expansion tank to reduce pressure issues. Shurflo makes one for RVs.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
