pulsar
Dec 20, 2014Explorer
It is not uncommon for the pressure release valve to "weep." The weeping occurs when the air gap at the top of the tank is lost.
If this is your problem, it can be corrected by the following steps, when the water in the tank is cold.
Turn off the water supply (pump or city water).
Open a faucet to release pressure.
Pull the handle on the valve straight out.
When the water quits flowing, let the handle snap shut
Close the faucet and turn on the water supply.
I don't know that this is your problem, but should be checked before replacing the valve.
Tom
Tom
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
