Old-Biscuit
Dec 21, 2014Explorer III
RJsfishin wrote:
Ironically, mine has dripped for a year or more. A week ago it got drastically worse. So I opened and closed it a few times, and it got worse yet, pumping water out like an open faucet !
I couldn't even imagine taking a pipe wrench to a 13 yr old heater, so I tefelon taped a 3/4" PVC plug and screwed it into the opening. Not leaking a drop,....and I have this feeling it will stay that way, unless I decide to somehow connect a new one to the old one.
Two issues:
First......doing what you have done. Water heaters have safety devices for a very good reason. Normal t-stat to control heating/operation, a higher temp t-stat as a backup to normal and then the T&P as a final safety device.
I operated boilers for a living, steam will KILL. A overheated/over-pressurized water heater WILL explode.
Please for your safety, your families safety and those that are innocent bystanders safety.............DO NOT CAP THE T&P.
If too afraid of replacing..let it drip.
Second......posting the idea of capping off the T&P is wrong and should NOT be suggested either directly OR indirectly.
This is NOT something to mess around with.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
