Fallin22's avatar
Fallin22
Water heater lighting
I purchased a 2006 cavalier FEMA trailer at our hunting camp and was wondering if someone can direct me on how to get the water heater to work? Thanks in advance
  • I'm pretty sure the previous owner said it was propane water heater
  • depends if it is DSI or manual, one way to tell is open the door, if there is a big blue knob ( the thermostat)on the front,it is manual light and you will need to turn a knob on the top of the area above the burner to pilot, hold it down and light the pilot hold for a few minutes and let the button up, then turn it to heat
    either way make sure there is water in the heater and air is out of the lines also run the stove for a few minutes to get the air out of the LP line.
  • There should be a switch somewhere to turn it on. then if you have battery coming to it and gas it should light right up. sometimes a second switch on the heater itself.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
