Teleman wrote:
rk911 wrote:
Teleman wrote:
Teleman wrote:
rk911 wrote:
to clarify...is your issue the light or there is no hot water? are you heating the water with LP or electric? LP tank empty? other 120vac appliances working?
No ignition. Plenty of propane. It's as if the switch itself is bad, though that may not be the case, but if the switch was bad the symptoms would be the same.
Sorry. It's an Atwood. I'm using it with LP.
LP only model or LP/Electric?
LP/Electric. Using it in LP mode.
ok, good. on our atwood the light only comes on when ignition
has not taken place. turn on your WH, wait 10-15 min and check water from a sink. you should feel it gettjng warm. after another 15-min it should be hot.
motor aid means that engine coolant is routed past the hot water tank when driving. that heats the water in the tank so no need to run the LP or electric when driving.
