Old-Biscuit wrote:
Teleman wrote:
Cleaned the multipin connector on the board and it fired right up. Indicator light still isn't working but a minor issue I'll address later.
Light on On/Off Switch is a FAULT Light---should come on when:
*Propane Flame Fails to light/fails to prove it lit
*ECO has tripped (failure of normal temp T-stat)
Reset Fault Light...turn switch Off then back ON
Got it! I was used to the old rocker switch-light that lit when turned on and went off when the thermostat turn off the gas. Water got hot so I'm good! Thanks!
